Frigidaire Affinity Front Load Washer Troubleshooting Guide
On By In Home
Frigidaire Washer Error Codes for Front-Load Washers These error code explanations can help you diagnose a problem with your Frigidaire front-load washer. For repair how-to help, visit the PartsDirect section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for and find. On washers without a digital display, the vertical row of 5 status lights blinks to indicate the first digit of the error code.
Frigidaire Affinity Front Load Washer Repair Manual Diagnostic Help, Error Codes, Wire Diagrams, and Part Testing For 6000 and 7000 series Affinity Washers.
The Start light links a number of times and pauses to indicate the second digit. For error codes that have an alpha character in the third position, the Start light blinks 10 times for A, 11 times for B, 12 times for C, and so on. Check out our for on a different Frigidaire model or another brand of washer.
Error Code Condition Check/Repair Shop Parts E11 Fill time too long Fully open the water supply faucets behind the washer. Check that the drain hose is installed correctly. If not, water can siphon from the washer through the drain. Check the drain pump for items such as paper clips and coins, which interfere with draining and also let water siphon out through the washer drain.
In winter, check for frozen fill lines. To check the water pressure to the washer, unplug the washer, turn off the supply faucets, disconnect the fill hoses from the back of the washer and put the hose ends in a bucket. Turn on the faucets; if the pressure is low, have a plumber repair the water supply. If water flows okay, the screens on the water inlet valves could be clogged, or there could be another problem with the valves. In either case, replace the water inlet valve assembly. (Don’t clean clogged screens, because debris from the screens can fall into the valves and keep them from closing).
Water inlet valve assembly E13 Water leak in the tub or air leak in pressure-switch air hose The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check the drain hose for proper installation according to the guidelines in the installation manual. Improper installation of the drain hose can cause fill water to siphon out of the tub and trigger the E13 error code. Check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems. Outer wash tub, Air hose, Water-level pressure switch E14 Dispenser drawer not closed Some models have a magnetic reed switch in the dispenser drawer housing that detects whether the dispenser drawer is closed.
If the drawer is closed, check to see if the magnet on the bottom side of the drawer is in place. Replace the magnet if necessary. Replace the reed switch if it's defective.
Dispenser drawer magnet, Reed switch E21 Drains slowly Check the washer drain and drain hose. Unplug the washer and check the drain pump for a clog. If the drain path is clear, the drain pump usually needs to be replaced. Drain pump E23 Drain pump relay failed The drain pump relay on the control board failed.
Replace the electronic control board. Electronic control board E24 Drain pump relay failed The drain pump relay on the control board failed. Replace the electronic control board. Electronic control board E31 Pressure sensor not communicating with electronic control board This error is only on models with a digital display.
Unplug the washer and check the wire harness connections between the water level pressure sensor and the control board. If the wiring connections are sound, the water level pressure sensor usually needs to be replaced. Water level pressure sensor E35 Water-level pressure sensor detects overfill This error is only on models with a digital display.
If the washer is actually overfilling, check the inlet water fill valves to see if they are shutting off the inlet water flow properly. If they are defective, replace the water inlet valve assembly. If the washer isn't overfilling, the water-level pressure sensor usually needs to be replaced. Water-level pressure sensor, Water inlet valve assembly E43 Control board failure Unplug the washer for 5 minutes. Restore power and see if the code returns. If it does, replace the electronic control board. Electronic control board E44 Control board failure Unplug the washer for 5 minutes.
Electronic control board E45 Control board failure Unplug the washer for 5 minutes. Restore power and see if the code returns. If it does, replace the electronic control board. Electronic control board E46 Control board failure Unplug the washer for 5 minutes. Restore power and see if the code returns.
If it does, replace the electronic control board. Electronic control board E47 Control detects an open door lock circuit in Spin mode Unplug the washer. Check the wiring harness for the door lock assembly. If the wiring harness is sound, the door lock/switch assembly usually needs to be replaced.
Door lock/switch assembly, Wiring harness E48 Control detects a problem with the door lock circuit Unplug the washer. Check the wiring harness going to the door lock assembly. If the wiring harness is sound, the door lock/switch assembly usually needs to be replaced.
Door lock/switch assembly, Wiring harness E52 Bad signal from the motor tachometer Unplug the washer. Check the resistance through the tachometer on the motor. It should measure between 105 & 130 ohms. If the tachometer is bad, replace the drive motor. If the tachometer resistance is within that range, replace the speed control board next to the motor.
Drive motor, Speed control board E55 Motor overheating Unplug the washer and remove the drive belt. Spin the motor pulley. If it doesn't spin freely, replace the drive motor.
If the motor spins freely, rotate the large drive pulley on the back of the washer tub to check the spin bearing. If the pulley doesn't spin freely, the outer tub and spin basket usually need to be replaced because a spin bearing failed. If the spin bearing is sound, check the resistance of the motor windings for a reading between 4 and 6 ohms. If the motor has failed, replace it. If the motor is sound, the speed control board usually needs to be replaced.
Drive motor, Outer wash tub, Spin basket, Speed control board E56 High motor current Unplug the washer and remove the drive belt. Spin the motor pulley. If it doesn't spin freely, replace the drive motor. If the motor spins freely, rotate the large drive pulley on the back of the washer tub to check the spin bearing. If the pulley doesn't spin freely, the outer tub and spin basket usually need to be replaced because a spin bearing failed.
If the spin bearing is sound, check the resistance of the motor windings for a reading between 4 and 6 ohms. If the motor has failed, replace it. If the motor is sound, the speed control board usually needs to be replaced. Drive motor, Outer tub, Spin basket, Speed control board E57 High current on inverter Unplug the washer and remove the drive belt. Windows File Protection Wfp Patcher Switcher Locomotives more. Spin the motor pulley. If it doesn't spin freely, replace the drive motor. If the motor spins freely, rotate the large drive pulley on the back of the washer tub to check the spin bearing.
If the motor has failed, replace it. If the motor is sound, the speed control board usually needs to be replaced. Drive motor, Outer tub, Spin basket, Speed control board E58 High current on motor phase Unplug the washer and remove the drive belt. Spin the motor pulley. If it doesn't spin freely, replace the drive motor. If the motor spins freely, rotate the large drive pulley on the back of the washer tub to check the spin bearing.
If the pulley doesn't spin freely, the outer tub and spin basket usually need to be replaced because a spin bearing failed. If the spin bearing is sound, check the resistance of the motor windings for a reading between 4 and 6 ohms. If the motor has failed, replace it. Dazzle Dvc 80 Driver Download. If the motor is sound, the speed control board usually needs to be replaced. Drive motor, Outer tub, Spin basket, Speed control board E59 No tachometer signal for 3 seconds Unplug the washer. Check the resistance through the tachometer on the motor.
It should measure between 105 and 130 ohms. If the tachometer has failed, replace the drive motor. If the tachometer resistance is within that range, remove the drive belt. Spin the motor pulley. If it doesn't spin freely, replace the drive motor.
If the motor spins freely, rotate the large drive pulley on the back of the washer tub to check the spin bearing. If the pulley doesn't spin freely then the outer tub and spin basket usually need to be replaced. If the spin bearing is sound, check the resistance of the motor windings for a reading between 4 and 6 ohms. If the motor has failed, replace it. If the motor is sound, the speed control board usually needs to be replaced.
Drive motor, Outer tub, Spin basket, Speed control board E5A Speed control board is overheated Replace the speed control board. Speed control board E5B Speed control board is overheated Replace the speed control board. Speed control board E5C Speed control board is overheated Replace the speed control board. Speed control board E5D Communication problem between the control boards Unplug the washer and check the wire harness connections between the main electronic control board and the speed control board. If the wire harness connections are sound, replace the speed control board.
If the problem persists, replace the main electronic control board. Speed control board, Electronic control board E5E Communication problem between the control boards Unplug the washer and check the wire harness connections between the main electronic control board and the speed control board. If the wire harness connections are sound, replace the speed control board. If the problem persists, replace the main electronic control board. Speed control board, Electronic control board E5F Communication problem between the control boards Unplug the washer and check the wire harness connections between the main electronic control board and the speed control board. If the wire harness connections are sound, replace the speed control board.
If the problem persists, replace the main electronic control board. Speed control board, Electronic control board E67 Incorrect voltage supply to the microprocessor Unplug the washer for 5 minutes and then plug it in.
If the code returns, replace the electronic control board. Electronic control board E75 Failed water temperature sensor circuit This error code is for washers with a digital display only. Unplug the washer. Check the resistance through the temperature sensor circuit. It should be around 50,000 ohms at room temperature.
If the sensor is defective, replace the water inlet valve assembly. If the resistance in that circuit's sound, replace the control board. Water inlet valve assembly, Electronic control board E95 Electronic control board communication error Unplug the washer for 5 minutes and then plug it in. If the code returns, replace the electronic control board. Electronic control board EB1 Incoming power frequency out of limits Unplug the washer. Have your local electrical power service provider check the power supply frequency.
If it's normal and the code doesn't clear, replace the electronic control board. Electronic control board EB2 Incoming line voltage is above 130 volts AC Unplug the washer. Check the outlet voltage. If the voltage is high, have an electrician repair it. If the voltage is normal, replace the electronic control board. Electronic control board EB3 Incoming line voltage is below 90 volts AC Unplug the washer.
Check the outlet voltage. If the voltage is high, have an electrician repair it. If the voltage is normal, replace the electronic control board. Electronic control board EF1 Clogged drain pump Unplug the washer.
Clear the clog from the drain pump. If the drain pump is damaged, replace it. Drain pump EF2 Too much suds Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer. HE detergent.
FREE Standard Shipping on orders of $90 or more Purchase requirement calculated before taxes and shipping charges and after other discounts have been applied and must be made in a single transaction. Cannot be applied to previous purchases and cannot be redeemed for cash. Valid for standard ground shipping within the continental United States and not valid for shipments to Alaska, Hawaii, Puerto Rico, Guam and the US Virgin Islands. Offer valid for online purchases only. In an event of a return, coupon savings may be deducted from your refund. Discount will be automatically applied during check-out. Sears Holdings reserves the right to terminate or modify this offer at any time for failure to comply with its terms and/or due to any operational malfunction of the software, hardware or equipment required to process this offer.
© 2013 Sears Brands, LLC. May not be used with any other coupon, associate discount, or during Family & Friends or Member events. 365 Day Return Policy You may return an unused and uninstalled part in its original packaging. To return a part, enter your order number/zipcode above and continue through the return process to obtain a Return Authorization number.
We must receive the returned part(s) with the Return Authorization number within 365 days of your original order date. Exclusions apply to products with limited shelf life, which includes but are not limited to batteries, smoke detectors, or chemical based products; these products must be returned within 90 days of the original order date. Items received damaged must be reported within 10 days of receipt. Credit will be issued for the part(s) plus tax, minus any shipping charges.
